TwinTurbo.NET: Nissan 300ZX forum - The cam seals are leaking and need to be replaced. >>>
Subject The cam seals are leaking and need to be replaced. >>>
Posted by ZUL8TR on December 30, 2009 at 9:14 AM
  This message has been viewed 450 times.
In Reply To trying to find oil leak...need some help posted by Adamo on December 29, 2009 at 07:55 PM
Message To do that the belt needs to be removed. Also the crank seal shouls also be replaced. If you have done the work yourself on the timing belt you just have to repeat it. However replacing the seals requires patience so read up on it in the tech section here on TT. Here are some links that will help:
[ http://www.twinturbo.net/nissan/300zx/forums/technical/view/1054425/Supplemental-Notes--120k-T-Belt-Servicing.html ]
[ http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=967023 ]
[ http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=809214 ]
ZUL8TR in Orlando,FL
